deltap
- Sep 3, 2004
- Wisconsin, USA
The video explains a lot. Put 3 stays on the mast.
Laser don't need no stays, why should he?
But I'm thinking composite as well. Start with a wooden mast of any shape you like which you can make for $50, and with $100 (at least around here) you can get 3 yards of 12k carbon at 50" width, which gives you the length you need at about 25" of width. For a 70mm mast diameter, that would give you about 6 wraps at .023" thickness per wrap. More as you approach the tip. That'll come out to as much carbon around the outside of the wood as your hollow aluminum was going to be, and it will be much stiffer and stronger than 6060. If you find you don't need that much carbon, you can get 6k sheet or only buy 2 yards of the thick stuff, and save 33% on the fiber cost either way. It shouldn't break your budget too much to get yourself some epoxy and shrinkwrap to lay it up.
I was always under the impression that carbon fibre composite was part science plus witchcraft and cost massive amounts of money, how much does the stuff cost?
Mark
Mark
The OP is in Lithuania, and has already told us a bunch of times that CF will be too expensive in his area.
We're sort of spoiled, we have easy access thanks to the purchasing power of the aircraft and military demands...
I don't know all that's involved with the flexibility of the mast relative to contributing to the sail shape, but could the sail itself be adjusted such that the aerodynamics were appropriate to the new mast stiffness profile? Surely that's an option, and easier to do some sewing that to make a mast?
Another wacko thought - how about going with something like a 50mm mast OD, and using simple linear strips of carbon fiber tape to adjust the stiffness profile over the length? It would take relatively little tape to make significant changes to the bending stiffness.
So you might have three layers along each side of the tube for the first 2M, two layers the third meter, then one strip at four meters. Or taper the width of the strips as you go up, it would accomplish the same thing.
The amount of tape (being just a limited reinforcement) would be so little that the actual cost should be that bad - perhaps under 100 Euro? Add some epoxy and prep supplies, still not that much.
You would need to ensure there's full epoxy coatings over the CF where it touches the aluminum, you don't want a galvanic cell being set up.
I'm still missing something in all this....a 5.5M long mast that is 70mm at the bottom....if it were even possible to convert those numbers to God's Units, we'd come with about 17 feet long and approaching 3 inches in diameter. The wall thickness of 3 mm is within a few inches of 1/8 inch.
In 2022, we'd figure out the cost of metal using the formula: Metal price + Sales Tax + Shipping + Biden Tax
Assuming you used a round tube to start (as originally suggested) That would equal something like: $200 + 16 + ? + $400 = $616 w/o shipping
I have no idea where you'd get the raw materials for $150...and then any tooling, consumables, and labor would also need to be free. $150 these days? That's a tank of gas and a cheeseburger.
Use a good mechanical engineering modeling program to see if your dimensions are going to work.
A thickness of 3mm (.118) is pretty thin for a windy day sucking into a large sail.
. . .BTW doo some test cuts with your plasma cutter on the material, including the welding of said cut edge.
CF is insanely difficult to get right.
Oh, and a million dollar autoclave.
Vacuum bag them and have them cure under a row of heat lamps.
And if I go with CF-reinforced wooden mast, then again, it is doubly labor intensive, risky AND expensive at the same time. I did suggest this option when I talked to the CF people. They said the same thing - unless I have a machine that can lay carbon fiber, a resin infusion system and a vacuum to compress it all, don't even bother trying it, as it will end up in failure. And even if I have that, I should expect at least several failures before I get it right. CF is insanely difficult to get right.
