Thank you for the extensive replies, guys. I like where this thread is going, there are some really great ideas here.
Originally Posted by petersen![]()
Laukejas:
If you have the expertise to weld a "longseam" or two as you suggest in your original post,..why not four " longseams"??
You could consider simply cutting tapered strips of sheet or light plate, and bending (brakeing) a 45* crease down the center of each strip and assembling four strips to create an eight sided
tube with four longseams.
Make the strips 4' or 5' or 2 metres long; or whatever is practical to brake. And start with two long strips and two short strips so you can join a next section with transverse welds staggered to avoid a full circumference heat affected zone.
You could use heavier material at the bottom. and lighter as you build toward the top, and taper continuously from bottom to top.
Much less complicated metal forming task, But the welding supplies would probably exceed your unrealistic budget.
petersen
Very interesting idea. This sounds a lot like making a wooden mast from wood strips (birdsmouth method). I little idea of how much welding would cost at this scale, I never welded so much in one go. I will have to run some maths.
As I understand, this would end up in a 8-sided mast that I would have to round using the water pressure method?
I read some more and it looks like petersen beat me to the strip idea. I like his idea of creasing the strips 45 degrees to cut the welding in half.
As far as the water pressure thing, I do not see why it could not just be left with eight sides. That is almost a circle anyway.
I cut a lot from the quoted post.
Notice
