So, I've once again backed myself into a design-corner and this is the best forum I can think of for material knowledge.
I am making an aluminum drawer/cargo platform for the rear of my new vehicle. The platform is already functional, it is the drawer bottom material that has me at a standstill (I also plan on using the same material as a "top" for the drawer for workspace when the drawer is extended). Now that I have priced the aluminum, though (for just the frame alone!), I'm looking for alternative materials.
Basically, the drawer bottom will be 32"x30", with full perimeter support on a 3/4" ledge, and ideally should be 3/16“ thick or less. I don't mind adding support, and know I will likely have to. (Thinking inverted Tee-bar for supporting two 16“x30“ sheets, or more, if needed).
The rear of the vehicle is usually enclosed, so moisture shouldn't be a regular issue, but I would like everything to be waterproof. As far as strength goes... If it can survive a Reese hitch being tossed in, it should be strong enough for me.
I have looked ad HDPE, but see reports of waves developing at this sheet thickness. I like the idea of composite boards, but am not sure how brittle they are.
Anyone have a brilliant idea? Or should I just stick with some sealed high-grade plywood?
