oliverarn
- Jan 25, 2009
- North of San Diego
I need to make some spindles for my oscillating spindle sanders. The Sander end is #2 Morse with a 1"step at the upper end of the Morse taper. The ones that take a rubber drum are 3/4" od. Smaller ones below 3/8" appear to be hardened rods pressed into the morse taper.
I am not equipped to perform any heat treatment or grinding. I understand that the spindle will gall the machines morse socket if an incorrect steel is used. I have a taper attachment on my lathe.
Thanks in advance.
Thanks in advance.
