mazak qtn-350my-ii g code
Apoca0018
May 17, 2024
Murtede
Hi.
I need to make in g code for a mazak lathe a program that repeat some parts of the g code x amout of times and in the same time incrument -x of Z of g54.
I cant find anywhere a way to do it.
Can some one help me?
Unfortunately you will have to have the apps guy set up a macro/use a #500 number . I tried everything back in the day with work shifts etc and could not get it to work using a G53.5 work coordinate system.Then you can use the standard M98 loop or whatever. Good luck
Can you give me an exemple to see?
As suggested, you may store the repetitive blocks in a separate program, and call this using M98.
As regards, modifying G54, another way might be to have the subprogram in incremental mode, depending on the specific application.
