mc9 help
werkzeug
Oct 28, 2014
question about mastercam9 . how do you manage/edit the operations file, the defauls file, and the mill parameter file, to set default conditions for drilling, contouring, boring, etc. ?
You need to edit your Operation Defaults.
You can open them from the same popup window where you set your material type, Group Comments, etc... It's been so long since I've used that version.
Are you asking about X9 or V9?
thanks Mtndew for your reply. i figured it out. its in: Main / NC Utilities / def ops .
edits ops and mill parameters and setup sheet is also there. thanks for pointing me in the right direction. V9 btw.
What are the maintenance costs per year on V9 these days?
