Richard Winn
- Feb 23, 2020
Here's what the wear looks like. This is on a 42 ft wide stripper header. Similar things happen in and under the combine, tractors pulling other equipment during and post harvest, etc.
Bolt heads on height sensor mounts:
Sensor bracket and floor pan of header. The "serrated knife" look is typical for straw wear, as once a groove is started it deepens continually. We will weld these thick parts. I'd like to use a spray coating on the underside of the header since it is only 1/8 thick.
Wear on the skid plates. They were skinned with 1/4" hardox 2 years ago and are now worn through. We will patch and hard face.
The inside of the header. This is primarily what I want to coat. The auger, floor, sides, teeth, cover, etc. And none of this is easy to remove, so I'd like to do it in place as much as possible.
How about powdercoating? It's basically plastic melted onto metal. IIRC, some include Teflon.
It involves proper prep, heat, and removing the part from under said machine.
I think the bedliner/undercoat was a rattle can product. Have also used various caulk tube products, which seem to adhere better. We didn't do any prep on the surface. It was the usual wavy mirror finish that grain leaves. You can see your distorted reflection in it, it's polished, but unevenly grooved. Roughing would certainly help, but we were attempting a fast fix.
Correct. But...he doesn't have any trouble doing that, evidently.
I am using some spray can truck bed liner on some spring clamps I am installing, mainly to prevent excessive scoring of the aluminum tube they will attach to. No results yet, but it seems to me that it could be considered for this. But you will have to go over the mirror surface with some sand paper first. And a wipe down with some alcohol or other solvent that leaves little residue would also be advisable.
Of course, you could always have an auto paint shop apply it.
I'm trying to extend wear life on various farm equipment that handles grain or runs in fresh harvested wheat stubble. Our equipment is just getting absolutely killed with abrasive wear. On the inside from grain, chaff, dust, etc. And on the outside, the underside of the machinery, from straw rubbing it as it drives through the field.
This is serious wear. The straw will cut the heads off of bolts that stick out, wear the bottom out of a transmission in a couple seasons. And mild steel seems to take it the worst of all materials. So I'm looking for a relatively easy way to put material back on large surfaces.
I know flame and arc spraying, etc. are out there, but haven't done either. What processes are best for primarily sheet metal work? Ideally something cool enough not to warp thin parts, that will stick well to highly polished surfaces (the bottom and inside of my header are shined like a mirror). A process that deposits long-wearing alloys, etc. on to steel, stainless, even aluminum. If it comes off, I want it to come off in little bits, not peel off in big chunks that will wreck machinery.
Whether this is a machine I can buy and use ourselves, or hire a shop locally to do is fine, but share what you know please!
Notice
