Nerdlinger
- Aug 10, 2013
- Chicago, IL
Hi Everyone,
I am skimming off .005" from a block of annealed 4140 with a nice Ingersoll face mill using wiper inserts @ 700SFM and .020ipt and getting some swirl marks. The attached picture does not quite show it, but there ARE swirls going both directions, so I do NOT think it is the perpendicularity of the spindle to the table. Also, it comes and goes AND it is not always a rhythmic pattern so I do NOT think it is just one insert sticking down or up a little more than the others.
I am doing it dry and just going right down the middle of the 1-3/4" wide block with a 2" cutter. Should I try to offset the cutter to the left a bit and do it in two passes? I was hoping to do it in one pass to minimize mismatch lines, but as long as it comes out in blasting/vibrating after heat treat we are good. In the meantime we are hand grinding the surface before vibrating and plating.
What causes that? Is it a sporadic built up edge that scrapes and then falls off so the next couple of cuts is good until it builds up again and then leaves another groove, etc? Maybe I need to increase the cutting speed?
Thank you for any help!
