BulletHead
- Nov 21, 2013
- Los Angeles
I'm trying to machine a bullet shaped cavity about .224" wide by .350" deep. My boring bar is .077" wide but hits the opposite side of the cut as the lathe backs off after roughing cuts. I'm starting with a .080" through hole. I'm using a Hardinge CHNC I with a 810T controller.
The lathe wants to move away from the cut ~.073" on the X axis and back out but there isn't that much room in there especially since cavity gets more narrow at its max depth. Is there some trick to get it to back away from the cut only 0.001" instead? I edited the tool dimensions but it doesn't seem to change how much it backs off the cut before going for the next pass.
The only alternative I can come up with is to manually program each of the roughing passes but I'm only taking about .002" per pass and that could be something like 50 passes. These little boring bars are $20 a pop so I'm reluctant to try anything too fancy
