Mits MV4800 Water Leak from Lube Hose
AGMantz
Jan 13, 2022
We have a Mitsubishi MV4800 WEDM that has been leaking from the left side of the machine. The water is coming out of the small hose that normally drains the bad lube oil or excess oil or whatever drains into the bigger of the two jugs that sit in there. The water will start leaking from the hose randomly and will last for probably 5ish minutes(long enough for a decent puddle of water and oil to form). I'm assuming I probably have a bad seal somewhere which is causing water to leak in but I am not sure. Has anybody ever had this problem before or know what's causing water to come out of that hose?
Thanks,
-AGMantz
