dll6
- Apr 23, 2005
- Washington
Continuing from my previous post
https://www.practicalmachinist.com/...-spindle-counter-balance-seal-blowout-400585/
I came across a new problem while reassembling the machine that I thought warranted a new post.
Before reassembling the sheetmetal around the spindle I was checking out why the spindle lube pump and cooling fan werent running and discovered a previous owner had disconnected them at the contactor. I quickly found out why.
A few minutes after powering up the machine spindle oil began leaking out the side of the spindle housing. It appears to be coming up from the spindle oil sump, somewhere under the spindle belt drive. I think its coming up from below the driven pulley and puddling in the belt drive housing then leaking out a 3/4" or so sized hole in the left side of the Z axis, normally behind the sheetmetal covering the spindle. I cant see exactly where its coming from.
I also dont see where the spindle oil sump is vented so im hoping if I vent the oil fill pipe that comes out next to the sight glass, and maybe lower the pump relief pressure, that will fix the problem.
I really dont want to disassemble the spindle, I have no manuals on how any of that comes apart nor have I come across anything showing the inner workings of the spindle. From my previous dealings with DMG Mori they will charge me way to much to be of no help. The last time I dealt with them I paid $500 for manuals and waited 2 months for what turned out to be a CD of PDF files, to come from Japan.
Is it possible the pump is pressurizing the sump and pushing oil out the top? Or am I just grasping at straws.
Any insight would be greatly appreciated.
