Moriseikiman
- Dec 1, 2022
I have this Mori Seiki AL-2B that won't turn the spindle normally on in the jog mode as it should. Instead the spindle starts creeping at speed of maybe about 5RPM and the speed potentiometer has no effect to it. Also the pot doesn't work as spindle speed override either as I think it should do as well. But everything else works fine, I've ran parts with it and the spindle behaves normally when running a program or in MDI. The potentiometer itself is also in tact.
I can use it as is but would be nice to have the spindle speed override working and the possibility to turn for example soft jaws manually.
