Joe Michaels
- Apr 3, 2004
- Shandaken, NY, USA
Moving out the Boxcar Machine Shop, Approximate date of Brown & Sharpe magnetic chuck
We were moving several old machine tools out of the boxcar shop last week. These went to the shop of the Hanford Mills manager. The boxcar shop had not been used in at least 15 years, and had become a repository for all sorts of stuff that no one seemed to know about. I found a wooden box with a toolmaker-made sine bar and some hardened and ground special tooling. I was hunkered down on my hands and knees to get the steady rest and 3 jaw chuck for a 16" Reed & Prentice geared head engine lathe when I spotted another small wooden packing crate. I dragged it out into the daylight and was surprised at how heavy the crate was for its size. I was also surprised to see the crate was made of rough-sawn lumber, nailed together with hand-driven nails, and had the stencilling on it: "From B & S, Providence, R.I." In addition, the B & S old style logo with the "solid head" square was stencilled onto the crate. The lid had been taken loose, so I was able to see what was inside the crate.
Inside the crate is a factory-new B & S permanent magnet chuck, about 6" x 10". It is covered in preservative and has some kind of waxed paper over the working surface of the chuck. It looks like it was never out of the crate or mounted/used. The construction of the crate, being made with rough sawn lumber that has darkened with age, and the hand-driven nails (as opposed to air driven), and the stencilled old style B & S logo really caught my eye. I know Brown & Sharpe pretty much wound up its operations as far as building precision grinders and presumably the chucks for them in the 1980's. This crate looks even older. I know even by the 1960's, B & S had moved to a newer plant in Kingstown, Rhode Island. No other data is stencilled on the crate, and the lid which would have had a shipping label, is not original to the crate. It is a piece of painted plywood cut to fit the crate, no nail holes in it.
Can anyone give a rough idea of how old the magnetic chuck and its crate are ? No one knows how it came to be in the boxcar machine shop. We did get a donation of a Covel surface grinder, which will find its way to my shop.
As for the boxcar shop and the Catskill Mountain Railroad: The politicians and tree huggers have prevailed to a large extent and 11 miles of Catskill Mountain Railroad track have been torn up for a rail trail. It was time to move out the machine tools from the boxcar shop before the whole works was scrapped by the County, who is slavering and champing at the bit to do just that. My buddy Earl has an ancient Austin-Western hydraulic crane with an I-H 6 cylinder gas engine in it. Earl showed up to run his crane. Of course, it would not start. It was like rolling our clocks back over 30 years to when Earl and I used to get junk running to work on the railroad when we had no budget. We lifted the distributor cap and snapped the points, decided the points were burnt and filed them. I told Earl he is not keeping up with the times, since new points generally do not have enough plating on the contact surfaces to allow any dressing. We got the points on high distributor cam lobe with me watching the cam and hollering to Earl who was jumping the starter solenoid with pliers handles. We regapped the points and still no fire. The rotor looked pretty well arc pitted, so we tried filing and emery cloth. Still no fire. Earl went to the old NAPA store where the parts men know our equipment and know about things like ignition points and caps and rotors. I got busy with the other fellows and used my pinch bar to pinch up the machine tools so we could get them on pipe rollers and work them towards the boxcar side door. Earl came back and we got the Austin-Western crane going. We started rigging out the machine tools and discovered the crane was low on hydraulic oil. We had a few gallons, but not quite enough. We had the machine tools on the lowboy in a rough position, but were going to move the rig and crane and re-arrange the load. Earl came back with 5 more gallons of hydraulic oil and we joked that the county officials and trail nuts would have a s--t fit if they saw us pouring it into the crane's hydraulic reservoir, wanting to know where the first batch of it went and wanting to do soil sampling and nail us to the barn door.
We got the rig spotted in a better location and Earl moved his crane. We re-arranged the load and lashed things solidly for the ride up to East Meredith, NY. Old firehose makes good softeners for load binder chains. Earl is 76 and I am 68, so we are a couple of old farts, but we did fine. We've been running together for 33 years, and rigging, repairing junk, fabricating stuff from more junk, driving around in old heavy trucks and running a railroad were all stuff we did together. We rigged those machine tools into the boxcar when the future seemed bright and to stretch beyond the horizon for the railroad and for the steam locomotive restoration. Now, we are old farts, the political and demographic landscape has pulled the rug (or the rails) out from under us, and we knew it was time to move the machine tools out and pass them along to someone who will appreciate and use them.
Even as we were removing the machine tools from the boxcar, the scrappers were cutting the rails and dragging them away immediately off the end of the boxcar. We are operating over the Kingston, NY portion of the line and doing surprising well financially. The Empire State Railroad Museum (ESRM) who owns Steam Locomotive 23 has no interest in continuing the restoration of that locomotive. A new generation of officers of the ESRM wants little or nothing to do with the actual Catskill Mountain Railroad and the running of trains, preferring to hold static exhibits and lease some of their property to the people running the pedal powered track cars (over a section of our former operating track). They are clearly pandering to the politicians and trail nuts and tree huggers who were carrying on about all the bad stuff associated with railroad equipment operation, repair and restoration. They wanted to get rid of the machine shop. I stepped in and made sure some of the machine tools went to a good home where I will be able to teach a new generation of people to use them to good purpose. The fellow who got the R & P lathe also got a Southbend/Elliott "Sturdimill" horizontal mill with a mess of tooling, and a 24" Rockford Hy-Draulic shaper with universal table, hydraulic tool lifter, and fresh rebuild and more tooling. I will be using those machine tools once again to make parts for Hanford Mills and teaching the Mill Manager- a young fellow in his 30's- about machine shop work.
The machine tools remaining in the boxcar consist of a 16" x 72" Monarch geared head engine lathe with taper attachment (1943 War Production Board machine), a 1930's Brown & Sharpe heavy vertical mill (number 50 NMTB spindle taper), and a Niles 30" vertical turret lathe from the 'teens. The smallest machine tool in the bunch is an Excelsior "camelback" drill. This machine is in about the best condition I ever saw this type drill in. The table has no "extra" holes, and the concentric rings for centering work and machining marks on the table are as crisp as the day it was made. The Excelsior drill and Monarch lathe will go to my buddy who was one of the founders of the Catskill Mountain RR. He's got about a 25 ton 0-4-0 Davenport standard gauge steam tank locomotive at his property, and we plan on restoring it within our lifetimes, free from the meddling of politicians, trail nuts, tree huggers and the efete snobs who took over the Empire State RR Musuem. He's got a 1960's Brockway truck tractor and lowboy, so I suppose us old farts will drive around renting the tank engine out and running it on hospitable railroads.
I ran jobs on all of those machine tools when we were going strong with steam locomotive restoration and with repairs to our diesel locomotives. The boxcar shop is awash in small parts from Steam Locomotive 23, and a second boxcar has the bigger parts stripped off that locomotive when we started restoration. Now, the museum would just as soon send all those parts to the scrapper. They have the frame and running gear and boiler, and the rebuilt tender (which we rebuilt) sitting on their property in Phoenicia, NY and are scared out of their wits to even discuss doing any work on it or restoring it. They won't hear anything about selling that locomotive to other historic railroad operators who really want to buy it and restore it to operating condition. Clearly, it was time for me to make a break with the railroad. I resigned from the Board of Directors last year. The Catskill Mountain Railroad, to survive, has gotten into the "theme train" business. Trains for Halloween, Easter, reviving the hippie era of the 1960's with a "Peace Train" (located within 15 miles of Woodstock, NY, so what else ?), and the perennial favorite of Polar Express. While this sort of thing has put the railroad in a very solid and strong financial position, it is not something I want to be a part of. I can't see myself being in what amounts to a "theme park" or "amusement park" type of operation. I am OK with repairing historic railroad equipment and even with cobbing junk rolling stock back together. I am also OK with doing engineering on bridges and acting as a consulting engineer to the railroad. I am NOT up for being in the midst of a theme park type of operation. We parted as best of friends, and I am kind of an "elder statesman". It took quite a bit for me to come to grips that the insanity of the rail trail was embraced in all quarters with support even from Chucky Schumer and the NYS governor. I swallowed the bitter pill of realization that we were not going to prevail as a political juggernaut with a full court press or screaming "greenies" and trail nuts with some big money behind them was what we were up against. Once I came to grips with that, I decided to move on. I am on tap as an engineer and machinist if they need me.
Cleaning out the boxcar machine shop was kind of "closure" for me. Sort of like cleaning out an old friend or relative's house/shop after they've gotten to the point of not being able to use any of it. Interestingly, the VP of the firm doing the scrapping got to talking with me. His firm is building a 54 Megawatt biomass powerplant since they have what he claims is "the world's biggest tub grinder" for grinding up stumps, trees, old railroad ties and similar. The plant will use wood gasifiers and run Solar gas turbines driving generators. The fellow told me they are up to their eyeballs fighting with what he called "the NIMBY's" (not in my backyard), and pretty much echoed my thoughts as to how people who holler for "green" or "renewable" energy suddenly go nuts and oppose a powerplant to do just that. He wound up asking me to get in touch regarding engineering work on the biomass plant which is still in the licensing and permitting stages. We shook hands, and as we told each other, it was nothing personal about his having the job of tearing out our tracks, but the doing of the politicians and similar types. We checked the lashings on the lowboy one more time, hugged each other and called it a day. The machine tools are in the Mill Manager's shop in East Meredith, NY and he is sussing out a rotary phase converter. I've got a load of odds and ends from the boxcar, stuff I did not remember bringing there, and stuff no one knew about. I found a Starrett 98 level in its box, and we gave that to the Mill Manager to start him off. The magnetic chuck in its oldtime crate is on a shelf in my own shop. In addition, I found a load of spools of lead-tin solder of different compositions and some was rosin core, some solid. I took most of it. I used to solder Detroit diesel radiators for the railroad maintenance of way equipment with lead-tin solder, and like to use it for odd jobs on non potable piping or electrical work. We joked that if the trail nuts got wind of the spools of lead tin solder, they'd have declared the boxcar as an environmental disaster and called for a hazmat cleanup. That's the way of the world, unfortunately.
