So the part of the gib that keeps it from going too far into the machine (that contacts the screw head side of the gib adjuster screw) cracked off allowing the gib to jam super tight and lock up the table.
Things I have tried:
Removed the ends that connect to the lead screw, backed the lead screw out to the left and wailed on the right side with a big ol’ urethane sledge
Used some threaded rod between the left saddle and a tab I bolted on to try to push the table to the left.
Tapping on the exposed right tip of the gib with a brass drift
Things I haven’t tried
Heat
Anyone have any other ideas?
EDIT: got it out. Ran a piece of threaded rod down the right side, under the table and grabbed the saddle. So that was under tension, the left side was in compression and then wailed on it with the urethane sledge. Fucker's out now. Here are pics in case some day someone runs into the same issue.
Heat
