steve-l
- Mar 2, 2012
- Geilenkirchen, Germany
When using high pressure BSPP fittings either bottom or top seals are needed. If on top, the fitting will have a flange under which a sealing ring or washer is often used, They can be soft copper, teflon , aluminum or a Dowty seal. Some other BSPP threads seal in the threaded hole like for pressure gauges. They can be also be made of various materials, but it is those I want to buy. What are they called?
