techymechy
- Oct 24, 2018
I own a Hardinge TM milling machine and I recently purchased a Bridgeport M head for it. I have an older Allen Bradley 240V VFD on the main machine motor and it works OK. The VFD usable frequency range is from 0-120Hz and it supports a potentiometer, works well with the machines FWD/REV switch and fit's nicely into the electrical box on the lower right-hand-side. It also has a torque boost for the lower RPM's, which works fine.
I think I have my frequency range limited from 20-100 Hz. The AB conducted a lot of noise to the 240V main. I tapped off of 1 leg of my 240V so I would have 2 duplex 120V sockets on the side of the machine. My Servo X axis power feed is plugged into this box. The noise from the VFD caused my Servo feed control not to work. I had to put a line filter for the 240 V single phase going into the VFD.
I'd like to have a separate 120V VFD for my Bridgeport Head and set up the same as the Hardinge motor. I was thinking of using the original FWD/REV switch as a control and mount a small box adjacent for the potentiometer control. I'll have to mount the VFD externally to the cabinet and would like to have it run on 120V.
I see that the supply of VFD's is fairly limited now. I'm also just a hobbyist and this won't be used very hard and really don't need all of the bells and whistles that come on these things now.
What brand, model and size of VFD would you suggest for my M head? Do you have a suggestion on where to buy one? I'm torn if I should try to get a used VFD on eBay. Do you have suggestions on a good used VFD? I need to make sure that the VFD is fairly quiet so it doesn't feed back into my Servo X axis power feed again!
Thanks,
Dave
Thanks,
Dave
