lindsey792
- May 26, 2022
Release lever can’t engage to tension the belt because the metal plug (not sure of its technical name) that fits between the plate on the lever and the piece attached to the spring is out of place. Do I need to disengage the spring to fit these back together? I’ve tried rotating the pieces so they come into alignment so I can fit this plug back through but that seems to require 4 hands (I only have 2) and a good deal of strength to rotate and fit everything together. I’m hoping there is an easy fix for this and I hope these pictures are helpful because it is a bit difficult to explain. Nothing appears to be bent or broken…
