Dear All,
I have a part which is 10" long and has various step diameter across length stating Ø.190" up to 2.5" length then Ø.250" to 5.3" length after Ø.420" up to 7.8" length and lastly Ø.312" up to 10". raw material is Ø0.5" SS316, since it is a hard material I cannot cut in single pass with current tooling. and also the guide bush we have currently is only 1.5" long, so I cannot cut each step OD separately, because the step lengths are more then 2.5". currently I am turning the part 1" length then 1" again, like this I was able to complete the part. but the part has band step marks on OD at every one inch length because deformation or mismatch. to make things even worse the part has very close tolerance ranging from 0.0005" to 0.002". Although I have fairly good experience with swiss lathe, I have never machined the parts this long and thin. so if anyone has experience with similar parts in swiss lathe, help me out.
I tried with sub spindle holding the part on synchronization mode, the part still deforms after parting. and also since the part has multiple diameters, I am not able to support the entire part with sub spindle.
Hope someone helps me out, thanks in advance.
