I have a small L'ish shaped steel part that I am having a hard time fixturing.
This is a big "production" run for me, approximately 350 pcs, which may never repeat. Too many pieces to do a one piece work flow, 3 operations, and the part is too small/finicky (I think?) to set up multiple in vice jaws. I played around with a setup to do 3 parts in a vise jaw, which may ultimately be the best value/speed combination. Not enough parts (or part value) to do a fancy intricate pallet, maybe a simple pallet, but I haven't come up with a simple setup for the second op.
I don't know if you will be able to make out the side profile or not. Total length is 1 1/4". Width is about .200".
1st op is easy, I can do some pockets and pitbull clamps. Second op I am having a hard time with coming up with a clamping or hold down solution. 3rd op is pretty similar, for either, it'll need to be a block to stand them up vertical.
I roughly have it planned out for 12 - 16 pcs on a pallet, cycle time for 16 should be about an hour that way. With two pallets, it'll be fairly quick to change over and swap parts while running. Problem is holding that second op. Machine time to make the pallets, mitee-bite's, etc pretty quickly racks up.
Maybe vise jaws are the way to go? 3 in the jaws, two ops in the orange vise, and the 3rd op block in the Kurt. 9 parts in process, say 35 min cycle time? $60 in soft jaws.
I've been spinning my wheels on this one and just can't make up my mind. One of the worst parts (I think) about being a one man shop, is not having anyone to bounce idea's off of, or to point out the "simple stupid" type things.
