EyeEmTrash
- Feb 24, 2023
What speed and feed would you suggest? The website for the drill suggest a feed of .01-.012 with 3500 rpm. I was thinking maybe 1000-1500 rpm, what would you suggest? Also does that feed sound high enough? I need to drill 12xDYou don't need a ton of coolant pressure, just need to keep the part cool while drilling. Heat will build up quick.
Depending on how deep you need to go you might have to retract all way to make sure coolant gets in there if you can't put it thru the drill itself.
