Hello all,
I'm restoring a Milwaukee router (model 5650) and would like to replace the two bearings while I'm in it, but am having trouble cross referencing these oddball numbers, and Google kept pointing me here on New Departure related info. If anybody either knows what the modern day substitutes are, or can tell anything from the dimensions, that would be a big help.
The labeling says:
(smaller bearing)
C 008 ND Made in USA
(larger bearing)
New Departure 016 Made in USA
Z502 Sentri Seal
* the 016 could even be 910 as part of the labeling is upside-down
The smaller one has metal shields on both sides with one which looks to be recessed at the outer edge by a couple mm.
The larger one has the recessed style metal shield on one side and a flush rubber seal on the other.
Milwaukee's part numbers are most likely:
small- 02-04-0850 (supposedly a 608ZZ)
large- 02-04-1610 (which is also listed as 16X35X11 BALL BRG 2 SE)
in some 5650 models, they are listed as:
small- 02-04-0895
large- 02-04-1655
The actual dimensions I get here with a digital caliper are slightly off from those specs in some areas, but that could be an error on my part, and I don't know what the tolerance typically is.
small:
bore- 8.026mm
O.D.- 24.003
width- 10.05
large:
bore- 16.025
O.D.- 35.02
width- 12.675
If there's any further info I could get or you need me to get a picture I'll gladly do so.
Much Thanks!
PS- It should be running over 20k rpm (I thought people recommended against rubber seals for that range).
The labeling says:
(smaller bearing)
(larger bearing)
Z502 Sentri Seal
small- 02-04-0895
large- 02-04-1655
small:
bore- 8.026mm
O.D.- 24.003
width- 10.05
large:
bore- 16.025
O.D.- 35.02
width- 12.675
Much Thanks!
