I haven't done any machining but am looking to make a purchase and was hoping you guys could steer me in the right direction for my first purchase.
Machine in question is a wells index model 55. The machine looks good in pictures and the ways seem to be pretty easily identifiable so it appears to have relatively little wear for a machine from the 50's.
The price being asked for it is $4000 and I'll post the details about it below. I'm not sure if runout is acceptable or if the features would warrant the price so please feel free to give me your opinions.
1. Total strip and paint.
2. Table surface reground flat and straight. 3. Spindle taper ground for R8.
4. New bearings in all the movements X Y & Z.
5. New custom felt way wiper.
6. New hand pump way oil supply directly to each movement ways and lead screw nuts.
7. New high precision ABEC7 Matched set of angular contact spindle bearings.
8. New bearings for the spindle motor & pully bearings.
9. All new belts.
10. New bearings in the quill power down feed.
11. New bearings in the quill manual down feed.
12. New bearings in the table power feed gear box & engagement.
13. New 3 phase 3/4hp motor for the table power feed upgrade from original 1/4hp motor.
14. 2ea new 3 phase VFD for variable speed power to the spindle motor and the power feed motor.
15. 2ea new VFD remote manual push button control panel, for motor start/stop, direction & speed.
16. Power on switch and control, switch for the two-speed spindle motor, high & low.
17. New VFD c/b panel and power contactor. 12’ 12-gauge 220v power cable with plug.
Measurements
1. Movement travel; X= 20-3/4” Y=8-1/2” Z= 16” Quill= 5-1/2”.
2. Backlash lead screw & nuts X= .012” Y= .005 .
3. Spindle runout at R8 taper= .0002.
4. Table length= 40”. Table Straightness; X- from Rt to Lt 1st 2/3 .0005. 1/3 left trends up .0015. Y-without vice trends up about .0015, with vice on table trends up about .0005.
5. Weight about 2200-2300 pounds.
9. All new belts.
Measurements
