We have a brand new machine, with a fanuc Oi-MF plus control. We have had some issues with the canned probing cycles, first we have broke 2 tips measuring z, different days at random using canned cycle, almost like probe does not rigister the surface on first touch, but this has only happened 2x out of hundreds we used it. Next is when calibrating probe on a ring, if i run the calibration cycle 5 times in a row, it will give me 5 different zeros, off by anywhere from .0004-.002 in either x or y, but it measures the ring accurately within .0001 every time. Finally, when probing a web on Y axis, we have found the probe center off by as much as .030 when it "finds" y center, but then recalibration shows it being off by much, much less. Any thoughts? we replaced batteries multiple times, checked and we are using correct brands and amp batteries called for in the manual.
