paulcnc44
- May 18, 2014
- bloomington indiana
Just bought this used, it is a 2007 model. When I command m112 to call up qsetter, alarm is generated that says m80 or m81 alarm. Not much explanation is given but appears there is a problem with the qsetter. I tried setting a tool manually by touching a tool on diameter and typing x2.5 and press measure button. 2.5 inputted directly into the x geometry offset box. Does anyone have any suggestions? I'm wondering if I need to somehow disable the presetter in parameters before I can measure tools manually. I need to get either of these methods working. thank you.
