Azoth
- May 10, 2019
- Houston, TX
Mazatrol Matrix Nexus controller on a Mazak Nexus 700D-II vmc using eia programs.
There are some behaviors I want changed that I'm hoping there's a parameter for. Have been trying to get them to buy the operator/programming manuals for the machine.
Bad behaviors:
Restart 2 nonmodal can be used to skip around in a running program on our Integrex, but it doesn't work on this Nexus. You can only choose the original point to restart at, but you can't skip down so right now I'm having to edit the program with GOTO if I want to skip down, and not forget to remove GOTO before the next part.
Hitting Reset also resets me to G0, G91, G54, and clears my supposedly modal Feedrate value. Would rather all of these remain modal.
Do you know if these can be corrected with parameters?
Bad behaviors:
