I recently purchased a Norton 6 x 18 hydraulic surface grinder. It is the older style, with the base that flares out at the bottom. I beleive the machine was produced in the '50's.
When I first looked at this grinder, I thought it had a plain bearing spindle, because there is an oil cup on top of the spindle housing. However, the spindle motor is mounted in-line with the spindle. I've never seen a plain bearing grinder with the spindle motor mounted in line with the spindle. Typically, the motor is mounted lower on the machine with the spindle being belt driven.
In addition, the motor has the name "Pope" cast into the housing. Also, the cap at the front end of the spindle is stamped "Pope". I know Pope made ball bearing spindles, but I'm not sure if they made a plain bearing spindle.
I have some reprints of Norton parts diagrams, but nothing that shows this exact type of spindle.
My concern is, I don't know how or what to use for spindle lubrication on this particular grinder until I determine what type of spindle it has. I really didn't want to start tearing it apart and screw it up.
Does anyone else have a grinder like this?
Also, I would like to get some manuals for this machine. I would be willing to pay someone for copying any manuals they may have.
Thanks
btm
Thanks
btm
