Hi all, this is my first post on here so figure I should give a bit of background before diving into my question. I'm 23 and a second year apprentice in Mechanical-Electrical Engineering but mainly specialise in machining, no CNC experience just manual machines from 70's-80's. It's a small workshop with only me and my supervisor so I end up getting experience doing a bit of everything, jack of all trades and master of some...
The question I had was regarding an oil drain I added to my Jaguar X-Type's AWD transfer box as the engineers/marketing considered this assembly sealed for life and therefore didn't design one into it. That of course isn't the case as oil doesn't last forever especially when it's only able to hold 600ml and lives beside the exhaust.
The process common among owners is to use the box's only accessible plug which sits too high to be a drain and too low to be a fill by jacking up the car in such a way as to turn it into those. One side jacked up drains most of the oil out and then jacking up the opposite side allows you to add oil back in. I personally don't really like this approach as it requires the car to be elevated 500mm from the ground to the sill and never actually drains all of the oil out, hence why I drilled a hole in mine at the lowest point. I can't take credit for this idea as an owner before me was the first to do this idea and one I followed for the future simplicity of further oil changes. What I instead would like to do is improve it and apply it to the rear differential also where the same problem occurs, only you suck the oil out through a hose into the fill plug (again considered sealed for life).
So here is how it is currently after doing the modification:
The plug is a modified engine sump plug that I turned down to 8mm and threaded with a M8x1.0 die. I figured a fine thread was more suited to a drain plug but that made the tapping of the hole in the transfer box slightly more tricky when you're working above your head lying on the ground...
As you can probably see in the first image is how vulnerable the plug currently sits under the car which is what I want to fix. It's sealed against a semi-flat surface that I filed which a rubber O-ring as a copper crush washer wouldn't have taken up the same slack that I left. Sealing compound won't currently work as I fill the box through that same hole with an adapter that I made so I can attach a hose going to an oil suction gun:
Any recommendations regarding the plug? A low-profile allen socket shoulder plug? Or a grubscrew/plug fitting with some sealant/Teflon tape?
The thread unfortunately has to ideally stay the same M8x1.0 as material wall thickness (~7mm) doesn't allow for effective sealing with a NPT/BSP taper thread.
Thanks in advance
Thanks in advance
