Bill D
- Apr 1, 2004
- Modesto, CA USA
I was surprised they did no rough casting of the teeth. Most cutting was done wit the tool upside down. I suppose it helps clear the chips faster.
Bill D
Bill D
hopefully the gear is going to turn very slow as the noise of the gear mesh running deep on one side and shallow on the other will drive anyone nuts.
Thanks for posting Bill D, a new 'can do' channel to watch and learn how it was done back in the day, but its today! Cheers mate!I was surprised they did no rough casting of the teeth. Most cutting was done wit the tool upside down. I suppose it helps clear the chips faster.
Bill D
Sure it will, the center of its driven gear to center of the drive gear cannot possibly be correct, as crudely as their center of the hub to center pitch line was machined, (think out of round in relation to the center hub) as it ramps through the center pitch line changing depth. Depending upon what it's driving there could be all kinds of interesting noise.
Nope. That's a function of involute curves and the way hobs generate the shape. That part was 3' in diameter or so, even using a sharp stick to center it you can come within five thou-ish, it'll probably sound a bit like a freighter in a following sea but won't be bad at all. Thats one nice thing about hobbing, you can do a shit job and it'll still turn out pretty good
it's still out of round.
But what do I know, we have only been manufacturing large gears since 1921, for those that use a sharp stick to measure that's over 100 years of gear cutting.
Your right to a degree, the gear would be centered to the the hub of the hob machine, All I said is will be out of round, and I still do as the gear blank being finished bored and then the hap hazard attempt to center the gear blank to the hob drive will most certainly be out of round. Did you go back and look how it was centered on the hob drive? the hub will cut deeper on one side then it will on the other. Anyway, Will it make a big difference probably not, WHAT I did say is depending on the driven load and speed it very well make noise, more so if it reverses. Probably O.K. in your world certainly not in ours.( think returned defective work)No, being mounted and indicated that way makes it eccentric, not out of round.
If the blank WERE out of round, it would 't matter. The teeth would still be round, centered on wherever the blank was centered when mounted.
Due to properties of the involute curve and the way hobs generate the shape, that part will mesh fine with its pinion. These are not cycloidal teeth that are really sensitive to center distance variation.
That makes you even older than me. Maybe the alzheimers attacked your understanding of basic theory.
For what it is, that part will be fine and it probably wont perform much worse than something cut with a class A hob on an L1800. The teeth are probably the best part of that ugly thing.
Similar mechanism was used on the antekithra mechanism to generate the 19 year cycle regarding the eccentricity of the moon and earth vs the sun.Doesn't matter if it 's out of round or eccentric the sfpm at the tooth is slower at the root than at the crest , a simple matter of the radius from center of rotation. As long as both gears run true no matter where they mesh the velocity of the driven gear will be constant through a revolution. However if one gear runs eccentric it will cause the other to speed up and slow down each rev. The sfpm changes with the radial contact patch as it moves in and out of the gear, the pd moves in and out, not to be confused with the normal meshing where the involute gives a constant velocity as long as the pd doesn't change.
An exaggerated example is a feed gear on one of our earlier presses that has an 8" or so driven gear that has the shaft hole about 1" off set . It is used to speed up and slow down the feed belts in the feeder. Without seeing the whole mechanisim it would seem impossible.
How it works is it has an identical plastic idler gear that runs true but is straddle mounted in a sizzor linkage that is connected to both the driver and driven and moves in and out to compensate for the difference in the eccentric gear radius as it turns. It runs fastest on the short side and almost comes to a complete stop as it passes the apexs. The difference is the pitch line doesn't change on any of the gears just the pitch radius.
It is simple to prove, mesh two gears loosly and lock one,move the other one in deeper in a straight line, according to you there should be no rotation on the loose gear. The same thing happens when the eccentric driven gear moves in and out of mesh with the driver when they are moving. The ratio doesn't change,cant, just the periodioc velocity.
Notice
