dalmatiangirl61
- Jan 31, 2011
- BFE Nevada/San Marcos Tx
Posted this in Material Handling and Rigging yesterday, but that forum is not working, and I need to fix this thing,
Replaced electric gasoline pump 5 months ago, bench test on old one said it was dead, ran machine for 3 days without issue, parked for winter, battery removed. Tried to start it a couple weeks ago, would not start, no fuel pressure, checked pump and it was not getting voltage. Machine has the propane fuel option, regulator was bad, but if I cracked valve on tank then closed it the machine would start and run for a few seconds. Replaced propane regulator this week, went to start it yesterday and it would not crank.
Followed troubleshooting chart in manual, on terminal #6 I got .56v with start switch not engaged, and 0v with start switch engaged. Wiring is in good condition, don't think there are any breaks, no rodent damage, maybe just a bad connection, IDK. In attempt to diagnose fuel issue I did move Control Relays 1 thru 4 around a few weeks ago, it made no differences, but still cranked.
After posting in MH&R yesterday I went out and moved Control Relays 1-4 around again, tried every possible combo, still no crank when start switch engaged, only 1 light on Ignition/Start Module was illuminated, #7 iirc. Came back inside and tried to find more info in Ignition/Start Module, not much out there, did find this https://www.genielift.com/docs/default-source/tech-tips/telescopic-and-articulated-booms/no-start-ism-models.pdf?sfvrsn=a40a768a_9
Went back out to check voltage at terminal #1 on Ignition/Start Module, and the damn thing cranked and all the lights came on on the module. At this point I'm thinking its either a bad connection, or the module has an intermittent problem. Its always nice when a machine fixes itself, but then you have to worry about when its going to die again. Any insight would be helpful.
Machine starts and runs on propane now, still dies when switched over to gasoline. Manual shows Control Relays 5-7 underneath 1-4, with #6 & #7 being Fuel Cutout Relays, but they are not in my control box. I did find 3 relays in engine compartment, different P#'s than those in control box, I'm assuming these are them, pulled one today to get part# and try to locate replacements.
