Scotti:
You ask an interesting question. "Bullfrog" was built during WWII if I remember the youtube correctly. That was a time of transition in shipbuilding from riveted to welded construction. Given the times and type of ship that "Bullfrog" was, my thinking is the ship was put together using rivets. Rivetting was a proven thing, it was in common use and the shipyards were set up for it, moreso than welding at that time.
Looking at a ship's hull, particularly after a few decades of slathered on paint along with rusting, it is sometimes hard to discern how the hull was put together. A riveted ship's hull does not have rivet heads projecting much beyond the exterior surfaces of the hull plates. The rivets are driven in countersunk holes, with a bit of a crowning just beyond the surface of the hull plates. This gives a 'fair' surface, with less drag in the water. Were the ship's hull riveted using rivets with a projecting head (such as 'acorn', 'button', or 'pan' heads), the thousands of rivet heads projecting from the hull would add tremendous drag.
The "Bullfrog" has what is known as a 'molded hull'. I.E., the plates are formed into curves in multiple axis. The seams where the plates meet are calked to seal them and make them watertight. Calking is done with an air rivetting gun with a blunt or radius'd end chisel steel in it. The calking chisel is driven into the edge of the plate overlaying or lapping the mating plate. The calking forms a groove in the edge of the overlaying plate and upsets the metal from that plate, forcing it into the underlying plate.
After decades at sea, a ship gets to resembling a hungry old horse, showing her ribs (frames). Years in heavy seas will cause the plates to be 'stove in' between the frames. The ship goes into the yards for repairs, and often, welding is used for the repairs. Plates may be cut out to access machinery inside the hull, or thinned or stove-in plates may be cut out and new plates welded in. Usually, on a riveted hull or boiler repair, the die is cast for continuing with riveting. It is easy enough to think in terms of welded repairs or alterations. However, welding sets up stresses, and tends to 'draw' as the welds cool. This can actually open up the calking on adjacent riveted seams. It is a bit of an art to determine when to continue with riveting vs welding. "Bullfrog" was a working ship. She was likely put into the yards and repaired and modified many times over her life. I am sure if a person were to get up close to her hull and take a good look, she'd have plenty of weld bead running on her plating and maybe some riveted plating patched in.
Even in this day and age, there is at least one shipyard up on the Great Lakes at Toledo, Ohio which still does riveted repairs. There are enough older hulls still in service on the Great Lakes for this shipyard (Ironhead, I think their name or nickname is) to keep doing riveting.
40 years ago or thereabouts, I worked on a job with an older gent who had been a shipyard boilermaker, and had worked on riveted hulls. We were working together on the construction of a new coal fired powerplant. This older gent told me how he'd been in a riveting gang and paid piece-rate, so much for each rivet driven. He told me he'd been driving what he called "Liverpool Rivets". He explained these were rivets driven into a countersunk hole. The other end of the rivet had a regular head (such as an 'acorn' or 'pan' head), and was stuck thru the holes from inside the hull so the plain shank stuck outside the hull. The heater, catcher, sticker and bucker (each of these guys has a specific job in a riveting gang) were inside the hull. The driver, which this gent happened to be, was on the outside of the hull. The gang on the inside would take an orange-hot rivet and stick it in the hole so the heated end of the shank stuck outside the hull. The driver would then "get on it" with his gun, using a 'rivet snap' which had a very shallow concavity. This fellow told me he made a lot of money driving those "Liverpool Rivets", claiming they had to be driven very fast because the hull plating would suck the heat away from the driven head way faster than with an exposed head. Being on piece rate, having to move fast to drive the Liverpool Rivets meant more rivets driven per shift and more money for the gang driving them.
Riveting is a method of construction that is not so bad as it sounds. It is definitely more labor intensive and makes for more difficulties in putting something together. However, when a rivet is properly driven, it 'upsets' to lock solidly in the rivet hole, and when the rivet cools, the contraction really clamps things together. This is known as 'bearing' in engineering. Riveted construction is quite an interesting subject in its own right. Having dealt with it many times on jobs over the years, I have some familiarity with it, and a LOT of respect for the crafts who built ships, boilers, tanks, and numerous building and bridge structures and so much else using riveting. When I see an old bridge or structure or some other riveted work being cut up for scrap, I get a momentary twinge, knowing how what it took to do that riveting. Not all rivets were driven by crews with hand-held riveting guns. In the shipyards, structural shops and boiler shops, whenever possible, rivets were 'power driven'. This meant using a 'bull riveter', a large "C" frame with a rivet 'snap' or set on it's 'anvil' or fixed end, and a rivet snap driven by a hydraulic cylinder (or large air cylinder). These bull riveters were made with C frames having enough throat depth to be lowered onto a piece of plate and reach the rivets on seams on the further edge. Shipyards had these bull riveters hung on light jib cranes, positioned so they could be lowered and easily positioned to drive rivets on seams on the ship's hulls and framing. This was known as 'power driven' riveting. It still required a riveting gang to heat the rivets in a portable forge or some other heating device, and to get the heated rivets to where they were to be stuck into the holes. Hence, the heater, catcher, and sticker were still on the job. On the large ocean going ships, hand driving all the rivets in a ship's hull would have been something that would have stretched the building time out for quite a bit longer. There are only so many men that can be put into a given space at any one time. The power driven riveting was key. Power driven rivets were a more consistent thing than rivets driven by men holding a riveting gun. Using the riveting gun was 'hand driving', a misnomer as 'hand driving' conjures up images of crews swinging riveting hammers.
As late as the mid 1960's, riveted construction was still in use on major projects in the USA. I know the Verazzano-Narrows Bridge (from Brooklyn, NY to Staten Island, NY) was completed about 1964 or 65. The towers on that bridge were put together with shop-driven and field-driven riveting. The American Bridge division of US Steel was still riveting on main structural connections on that bridge in '64 or '65.
