Title should be water well but can't fix it now.
We are on our own well which currently has issues. Figured it was worth checking here as some may have seen similar things or worked on this type of stuff.
House and well are about 40 years old. Well is 300 ft deep, standard 6" dia, pump at about 200 ft. Have owned it for about 22 years, no issues except we replaced the well pump a few years ago, it was original and 30+ yeas old. A few weeks ago had low water pressure, figured maybe it was the pump (figured weird that a new one would fail ~4 years), anyway shut the pump off overnight, in the morning switched it on and it recovered to full pressure. Figured maybe intermittent ... Keep an eye on it. About a week later it does it again. Call the well guy, comes over the next day seems the well is not making the water it used to, recovery time is to slow. Can frack the well, ok sounds good.
Limp things along for the last 2 weeks, supposed to happen on Monday now. Yesterday got home low water pressure again, and no one was home all day. Really weird. Then I notice behind the house near thw well head is all wet and flowing water - things had dried out so this is weird. Shut pump down, and water flow in that area quickly stops and it gets drier over the next few hrs. Turn pump on at 11pm goes from 15psi to the 62psi shut off point (3min7sec). Shut valve to house off so ther is no question of a slow toilet league etc. over the next 1/2 hr the pressure drops 4psi then stays there overnight.
My theory is low performing well - still needs to be cracked (a good well should have at least 4-5 gym which shoukd fill the entire water column in under 2 hrs it's not doing that. In addition, I think I have a leak in the underground line from the well to the house (the flowing water yesterday with low pressure and no one home), I also suspect the check valve at the house is not always holding, that would explain why it pumped itself dry when no one was home - water flowing in backyard. A leak underground would also explain why it took 3 min to pump to pressure in the house - it is loosing water to the ground every time it pumps.
So it seems like
Frack well
Replace check valve etc in tank inside house.
Fix line from well to house
Anyone with experience in wells think I'm on the right track.
Thanks
Paul
So it seems like
Frack well
Thanks
Paul
