The problem with most of the safety stuff on current machines isn't that they are there, rather that they render the machine virtually impossible to set up properly.
Inability to turn on a spindle with door open eliminates the old fashion edgefinding.
Dialing in a tool for a blend is also out.
Touching up a chuck jaw on a lathe is out.
I can go on and on.
So, to help out in times when the need is there, one tends to either bypass, or permanently remove a safety device.
Would it not be better if the MTB-s designed their safety equipment that it does not need to be fucked with?
Have the safety device be fully protecting the operator - and the machine as it may - during normal, standard operation, but have the ability to bypass or ignore some of it during the
non standard times such as setup or repair of something.
I have 2 lathes from the mid 2000-s that I have never felt the need to bypass anything, even though they have them.
I have EDM-s that have only one switch disabled, but if you saw it you'd realize it didn't protect you from touching the EDM wire, it only protects you from touching the EDM wire IN THAT PARTICULAR PLACE!
On some others, I had to go to fucking town and more-less remove the safety device completely, even though there is a so called "setup-mode" that should eliminate that need.
