All the G offsets are set to zero. Setting 33 was set to Fanuc, switched it over to Haas. Ran a program and z is off by 2". Is the G52 z registry somewhere different
than the offset page?
Switched from Fanuc to Haas and Z was still 2" off.
Looks like setting 33 solved my problem. Everything is right now. Thanks Bill.
Seems like some of the rest of you just post to hear yourselves talk. Just because I'm new to a machine doesn't mean I haven't done lots of research and read the manual or have lots of machining experience. As for the crashing the machine comments, I know what the machine costs, I wrote the check.
Where is Setting 33 at now?
If in your first statement that all of the G offsets are set to zero, then simply changing setting 33 will make no difference. Something else was changed.
I am not sure why you have taken such offense to the responses here. Perhaps you should reread the replies and reevaluate your position. The only one close, and not very close in my opinion, was the comment about the expense of machine repairs, but he did qualify his statement also.
You asked for help, and in my opinion, you were given very good suggestions even from mjk. By your own words admitted that this was your first CNC and therefore it is reasonable to assume that your experience level is low. This is not to say that you are ignorant, dumb or otherwise but merely inexperienced with a CNC. There are MANY smart people here willing to give their time and knowledge for nothing more that the satisfaction of helping others.
Unless you do not wish to solicit any other advise, I suggest you reevaluate your position on comments that are made either with this thread or future threads. Be aware that you will most likely get straight forward answers, incorrect answers (I have given some), smart a$$ answers, and even a$$ hole answers, this is life on a public forum. Take the good and ignore the bad as best you can.
Good luck with your machine!
