Can you please send me the download link, think it should work for my DMU70V.
Ihave send you email with my hard drive image it is V4.00 MillPlus from my DMU50evoOn the DMU 5V MillPlus 1996 machine (5-axes), an error O 208 pops up after loading. Probably the information on the hard disk is damaged . I ask for help. [email protected]
در دستگاه DMU 5V MillPlus 1996 (5 محور)، خطای O 208 پس از بارگیری ظاهر می شود. احتمالا اطلاعات هارد دیسک آسیب دیده است. من کمک می خواهم. [email protected]
PLEASE ANY HELP,THANKSHI, happy new year to all! i have problem with dmu50v, we bought maschine with software v420 but configuration of the maschine is y axis as main axis-, so y and z axis are switched. when y switch on control board is pressed on screen is correct but z axis move whichever configuration we try stay the same, shud we install new software or is possible otherwise. or some other maschine back up. thanks for help!
I do have a full set of backup discs for Millplus V4.0 for my DMU50v. Ive copied these in case anyone needs digital versions to rebuild after a trashed drive on the same machine. Pretty sure all youd have to insert your machines parameters into the flies to replace my shipped parameters.
Hi!Thanks
I have the BIOS re-entered.
The machine boots up but when it comes to the machine screen I get alarm for "parameters missing", then it reboots again.
I have read that the BIOS battery also holds a SRAM memory with start up parameters and the only way to get them back in is to reinstall the software.
Translated from a french forum, I have read about same solution in industryarena.
Machine finally repaired!!!! WOW!!!
The problem was that having emptied the EPC-8 card of its memory, the machine parameters went completely to the strawberries. Impossible to be able to put them back in a normal way because they are stored on an SRAM memory integrated into the card itself. It was necessary to go through the machine installation software (provided with the machine on diskette) which works only on a PC running under DOS.
I dont have the diskettes either, I pasted the answer from an old french forum.Hi!
I´m having the exact same problem but i didnt get the diskette with the machine. Can you please send me the files by email? alex @ schermansab . se
Hi! And thanks for replying!I dont have the diskettes either, I pasted the answer from an old french forum.
I finally solved this thanks to drimjohns mirror image disc, great thanks! In the service menu with that disc I was able to
"load default parameters". With my v331 disc that was not possible.
Dear markpI do have a full set of backup discs for Millplus V4.0 for my DMU50v. Ive copied these in case anyone needs digital versions to rebuild after a trashed drive on the same machine. Pretty sure all youd have to insert your machines parameters into the flies to replace my shipped parameters.
Уважаемый abelcncВсем привет,
Размещая документацию моего dmu50, я нашел способ выполнить кинематику в MillPlus, Heidenhain и Siemens. Отсканировал, если кому нужно могу поделиться.
Notice
