Maybe “ horse play “ doesn’t translate in the USA. In the UK it means “ Fooling around “. The lads were fencing with files and it all went very wrong.
Before I knew the guy had a glass eye I was drilling some 2” holes in a machine foundation for holding down bolts with him. We were using one of those old and heavy “ Black & Decker “ two handed drills. I had the control handle and my pal was holding onto a length of steam pipe screwed into the drill frame.
The carbide tipped drill was slightly bent and the further the drill went into the concrete the more it was shaking us about. When we had about an inch to go and the shaking was pretty bad my pal started shouting “ Stop, stop ! “ and began looking up at the sky.
I thought “ No way, if we stop now it’ll be a bugger to start again “. So I carried on.
He carried on shouting “ Stop, stop !” So eventually I had to stop drilling.
I said “ What‘s the problem Norman ? “
He said “ It’s my glass eye Tyrone, the vibration was causing it to nearly fall out !”
That‘s how I found out about his accident.
Regards Tyrone.
