magneticanomaly
- Mar 22, 2007
- On Elk Mountain, West Virginia, USA
I am looking for some education.
It is a truism that plain bearing machine spindles do and must turn slower than rolling-element bearing spindles.
However, IC engines almost all have plain bearings supporting the crankshaft, and these run at many thousands of RPM. I have read the articles in Machinery's Handbook and Marks Handbook on plain bearings, and I understand that the faster a spindle turns for a given oil viscosity, the more load it can carrry., and conversely the slower it turns, the heavier oil you need to carry the same load,,,to a point.. It's the hydrodynamic oil wedge, same idea as a motorboat getting up on plane.. As a spindle turns faster, the oil also must be thiner so that too much energy will not be wasted in viscous drag, and also so that it will not overheat because of the same lost energy turning up in the bearing as heat.
I also know that engine bearings have pressure lube, or at least ample lube from splash or directed dippers, whereas slow plain machine-tool bearings usually have only wick or maybe drop-feed lube.
At last the question: Could you not run a plain machine-tool spindle bearing at some arbitrarily high speed, if you gave it enough thin oil to keep it cool?
