I have a Powermatic lathe with a delta VFD-B. It has sat for years before I purchased it and when I got it home and wired it in . The VFD would not let me put the paramilitaries to the factory setting . The lathe will not run . I have 2 other lathes of the same model and I copied the wiring since they are working . I even went and bought a new VFD AND IT STILL SHOWS ERROR after I put in the factor reset code . Is there something mechanical I'm missing or any test I can do to start eliminating components to verify the VFD is ok if I have a problem with the motor or control panel .
