metalmagpie
- May 22, 2006
- Seattle
I just brought home a Hilger and Watts autocollimator and a Nikon mirror on a 5" base. I want to use it to map out a 36x36" surface plate.
I have two questions.. First, given that I have drawn my British flag pattern with 7 measurements along an edge (not diagnonal), I believe the autocollimator is set along the line of measurement, with the mirror set at the 4th measurement i.e. along the middle of the line. I believe the autocollimator is zeroes on that mirror position and then the mirror is moved to the other 3 locations along the far end of that first line, taking measurements. Then do I move the autocollimator to the other end of the same line, put the mirror back in the middle position, and zero the autocollimator again and take the readings from the second half of the line along the edge? I believe this is what the Standridge guys did in Oxtool's video. I'm trying to see how data taken from two autocollimator positions can accurately reflect the surface. I hope the question is clear. Thanks for any clarification.
Second, how do I deal with the fact that I cannot get an integer number of intervals along a diameter, not and have the interval be the same as the one used along an edge line?
Thank you. BTW I intend to use the Moody method to calculate actual microinches of error. I have this idea I can maybe implement that in an Excel spreadsheet. My goal is simply to learn how to measure the flatness of a surface plate.
metalmagpie
metalmagpie
