BKWtoolmaker
- Jan 31, 2023
Looking for someone with knowledge of a Pratt and Whitney 12” vertical shaper. I bought one last week that was in good overall condition. The problem is the clutch lever that runs the ram is locked engaged. When I went to view the machine to purchase it was disengaged. Upon startup the machinist Engaged the lever with a very hard pull that I assume locked the clutch. I don’t mind getting into the guts of machines but thought I would put this out there to see if this has happened to anyone else. Today I pulled off the clutch drive plate assembly to see if I could find anything that stood out. Found nothing out of the ordinary. I then proceeded to take off the rear access cover to look in the back of the head. Oil level seems good. There seems to be a sleeve inside that is connected to the friction pulley links. I noticed that the links had been maxed out of travel. I tried slipping a pry bar inside the head and prying slightly against the sleeve while at the same time having another person pull on the lever. I couldn’t get it to move so I decided not to force it. I then removed the bolt on the opposite lever to isolate which side of the machine had the issue. Confirmed it was the clutch side because the other side moved free when separated. I think tomorrow I am going to try and remove the whole main drive pulley/ clutch assembly to see if I can find anything that stands out. Where are all those Pratt and Whitney service guys. Retired probably. I have had many machine tools apart so mechanical aptitude is excellent.
