My pressure regulator dryer combination are showing its age. Is there a "go to" pressure regulator for blast cabinet?
One thing i have noticed on my regulator is that blast PSI is dropping as tank PSI is dropping. For example if tank is at 140 and i set regulator at 60 with peddal in and flowing, then by the time tank drops to 100 the pressure regulator at full blast is showing like 45... Not exact numbers, but close... Anyhow, is this just an old regulator that needs to be replaced or are there different types of regulators, some of which will overcome this problem by having a variable openning to yeild constant output PSI with varying input PSI as long as input stays above output that is?
