4GSR
- Jan 25, 2005
- Victoria, Texas, USA
If your lathe will swing this, drill and bore it in the lathe instead of the mill. Or rig it up and line bore on the lathe.
Thanks Ross for taking the time.So too late to make this right, but i would offer some pointers fro future work.
material looks to be cold finished.....Lots of internal stress in that stuff.
Would have drilled a through hole first close to required size.
Then cut the slot for your clamp. drill and tapped for the pinch bolt. fit sims to be tight in the slot...leave the shims long to protrude into the bore.
(this will eliminate having an interrupted cut at the slot when boring) Fit the pinch bolt and snug up....Slot done before the finished bore will eliminate post slot movement that can disrupt the bore.
.I am with the poster that suggested a solid boring bar directly mounted in the spindle, at the vety least a full 3/4" bar with a separate tool bit in a cross drilling for your boring head.
Set size by moving the tool bit, use indicator to gauge....
Best on your BP clone to feed using the knee.....Make a simple driver to fit the elevating crank dog coupling and use a cordless drill to move the knee.....
Sharp tool....Perhaps an Aluminum style positive insert with a very small radius on the nose.
Cheers Ross
Use what you've got on a one-off job like this.I'm beginning to feel like a machining genius now that I see that setup. I cant imagine a better job for a reamer/cutter as opposed to a boring bar. All day long.
TPMT/ TPGT would work well, STFCR is the boring bar code from memory. Front clearance (looking down at the top of the insert) is either 0 or 3deg, so it doesn't leave ridges on the face of the bore like a pointier bar will, if that makes sense. You can get TPMT (molded, for steel/ CI) and TPGT (ground, for alu/ plastics) in all kinds of grades and coatings, they're really common.What style of indexable tip boring bar would you guys recommend, for a Criterion 3/4" head ?
I see several with TPG inserts, but I hate them from my experience in a facemill.
Main use would be low carbon steel, on a vertical CNC.
Thanks
Bob
Notice
