IQRaceworks
- Jun 18, 2010
- MISSOURI
I'm trying to find a better/faster way to cut keyways in 1.5" diameter steel shafts.....similar to what you would find on an electric motor shaft.
The way we are currently doing it is with a Bridgeport mill, a v-block type mount on the table, and an endmill cutter. We set it up, cut the keyway on one end of the shaft, unclamp the shaft, flip it around, reclamp, and cut the keyway on the other end. It works, but it's slow. I'm trying to find a way to increase production.....possibly either doing multiple shafts at once (horizonal mill with multiple cutters?), or maybe a CNC mill type setup with multiple shafts clamped to the table at once.
The shaft are around 16"-20" long, and get a keyway cut on each end.
Just looking for some ideas. Thanks!
