Programmer/machinist needed, Novi, MI
empower
Sep 8, 2018
Novi, MI
I'm looking for help in my R&D department. this is an incredible company to work for and a fantastic opportunity for someone looking to grow. Located in Novi, MI, i'll be needing help programming, setting up and running all kinds of parts, we primarily work with aluminum. Currently have 3 CNC mills, 2011 Haas VF4, 2020 Zimmerman FZU32 with siemens control and 2021 Ibarmia Star L1500 with Heidenhain 640.
you should be familiar with these controls, or be able to pick it up FAST. no, we will not buy mastercrash, you'll use either fusion 360, or preferably NX, should be willing to learn NX regardless of if you know it now or not.
pay is starting at 30/hr, if you're closer aligned to what we want, pay will be up to 40/hr.
PM me here if you're interested.
Job Description
Job Title: CNC Mill Programmer
Reports To: Mechanical Manager, Technology Integration
FLSA Status: Non-Exempt
Job Summary
The Technology Integration team creates innovative prototypes, demonstrators, and experimental vehicles on a rapid development cycle to showcase ONE’s battery technology. It is a small team with a hands-on approach to all aspects of battery integration requiring each member to be energetic, adaptable, and easily collaborate with colleagues.
Your role will be a CNC Programmer/Machinist who collaborates directly with the engineers and technicians within Our Next Energy.  You will be able to assist in the design, creation, and development of systems.
Essential Duties and Responsibilities
Responsibilities for CNC Programmer
  • Read technical drawings and set up the machines in accordance with these blueprints
  • Use computer software to model cutting paths and program machines accordingly
  • Perform quality assurance tests to ensure products meet design specifications
  • Adjust machine cutting paths or settings to optimize production while maintaining quality
  • Select tools required to cut particular materials and program machines accordingly
  • Troubleshoot and resolve problems with machines as they arise
  • Provide feedback to engineering team about manufacturability issues,
  • Perform basic machine maintenance
Qualifications for CNC Programmer
  • Previous experience operating and programming CNC mills is required.
  • Strong preference to machinists with previous experience with HAAS, Heidenhain or Siemens controlled machines
  • Experience with Fusion 360 CAM or NX CAM desired
  • 3-Axis experience required 5-Axis experience desired
  • Must have strong attention to detail
  • Familiarity and skill with interpreting technical drawings and blueprints
  • Skilled at troubleshooting and resolving mechanical or logistical problems that arise
  • Ability to work independently and closely follow directions is essential
  • Should have a positive and professional attitude
  • Capable of standing for extended periods of time
  • Required Highschool education
Physical Demands
The physical demands described here are representative of those that must be met by an employee to successfully perform the essential functions of this job. Reasonable accommodations may be made to enable individuals with disabilities to perform the essential functions.
  • Sit at a desk and work on a computer for prolonged periods of time
  • Walk/move around and/or travel as needed
  • Ability to lift up to 40 pounds for short periods of time
Work Schedule
  • Full-time
  • Work schedule to be established with supervisor to ensure Company’s client and business needs are met
  • Flexible work schedule and environment, see company policy if applicable.
Miscellaneous
Our Next Energy, Inc. is an Equal Opportunity Employer and does not discriminate on the basis of Sex or Gender identity, Mental disability or physical disability, Religion, Age, National origin or ethnicity, Sexual orientation, Marital status, Veteran status or Parental status.
Notice: Depending on your specific placement, you may be required to prove that you have received the COVID-19 vaccine or have a valid religious or medical reason not to be vaccinated.  Our Next Energy, Inc. is an Equal Opportunity Employer and reasonable accommodations will be considered.
