jakob
- May 27, 2011
- Netherlands
The floor is pretty stiff. Right now it is supported at 4 corners. Along the sides i have welded pieces of t iron cut from the same i beams in the top. Also for fastening tool cabinets and the like. Its about 1 ton heavier then a normal empty shipping container. These are old containers, already had one side removed, i got them for free. They functioned as horse Stables, at that time they where welded together at the open sides. I plan on space in between. These old containers where build from thick hot rolled sections, the new ones are mostly out of folded sheet metal. I prefer the old containers. These are old DDR containers. The floors are made of 50 mm thick wooden planks. The machines are bolted to hot rolled steel frames, I made those in my workshop and welded them in later. Lots of rust repair had to be done.
Verstuurd vanaf mijn CPH2211 met Tapatalk
