Question about cutting a radius and the insert used.
Hi EyeEmTrash:
You do know that if it's just a pulley, you can get away with a carbide or HSS rod of the proper diameter brazed onto the front of a piece of steel at a slight angle to give clearance and then just plunged in as a form tool?
A hacker bodge if you have a CNC lathe, but a bazillion pulleys have been cut that way before the days of CNC.
Cheers
Marcus
www.implant-mechanix.com
www.vancouverwireedm.com
Or, program the exact radius you want with TNR and use whatever tool that fits into the groove !!! ;)
That's great to know !
But it's not what he asked. He has one insert and wanted to know if it would work. Answer : yes. For example, if he likes, one statement will make his desired arc with that insert.
If he decides to engrave the history of the kings of england in 17-4, I'm sure he'll be back for more info later.
Just program a bunch of pointless extraneous moves and wow, it certainly is difficult to deduct the radius of the insert from the radius of the arc, I had to call UC Berkeley and schedule a consultation with a post-grad math major to get an answer !
This comment was not for YOU. I know you.
