Machinerer
- Jun 12, 2009
- Clearwater, FL
I have a few questions about the 4 orange vises we have on a tombstone, if anyone here is using them in a similar setup.
What do you do to hold the carrier up when you're changing jaws? I find can be pretty dangerous when you're taking a jaw off the dovetail with one hand, and trying to hold the carrier up with the other hand. I've had the carrier slam down to the bottom a couple times.
Some jaws come with set screws with spring plungers, and some jaws come with regular set screws. What's the purpose of the set screw if it's only in some of the jaws?
Do you run into problems with only being able to clamp a small range of sizes? I find that every time I plan a setup, when I go out to the vise it doesn't work Either the carrier won't open enough, or it won't close enough. The center blocks are big, the outside jaw blocks are big, and the "extra" material on the carrier is big, which often stops it from closing enough.
I'm finding it to not be nearly as versatile as we'd hoped for, and every setup seems to take way more trial and error, and re-do's than it should. Could entirely be that we're doing something wrong, but I'm not sure what that could be.
