When you switch from dual to single, if you close the front station (top on the horizontal) with or without a piece of stock, then release the brake on the rear station, the carrier+jaw weight is resting on the center jaw. You can then remove the rear jaw and open the carrier to the correct position for single station use. Install the rear jaw with pins, then remove the center and top. No more dropping the whole carrier.
