Reading Suggestions
Gorby
Aug 13, 2022
What are some go-to resources for general machining knowledge and strength of materials information, primarily in metalworking? I’m looking to get into machining as a hobby and would like to give my brain a head start until my wallet can afford equipment.
I like shopping at used book stores, and library book sales, you never know what you will find, and some are a wealth of information you just won't find anywhere else. If you have not read it yet "How to run a lathe" is a good primer for anyone wanting to learn, and it is available online. "Machinery's Handbook" is another must-have book, you don't have to memorize, you just need to know where to find answers to questions in it.
Go to vintage machinery, Mr Keith Rucker has been making digitised of lots of engineering books not available anymore ( mores the pity) worth a look,
Treatse on milling is brilliant, how to run a lathe, atlas
Go look, I’ve been reading workshop books for 55 years, still learning, just finished one from 1856, how to shorten a connecting rod ! ( heat cycling ) was just one chapter, there’s a wealth of stuff out there, much is pdf now
Mark
"General machining knowledge" and "strength of materials" are two separate areas, not likely to be addressed in any one book designed for people looking to get into machining as a hobby. For the former, consider seriously
Be sure to get both volumes.
For the latter, a lot will depend upon what your aims are and how technical you want to get.
-Marty-
-Marty-
Maybe I wasn’t clear enough. I understand they are two separate areas and am looking for recommendations for both areas. For strength of materials I am looking for a general understanding as well as a more in-depth study on how different steels hold up to pressures and tensile strength.
Gordy, send me a PM, I'll get you a list of some 15 to 20 books I have come across on ebay that have guided me over the last 20+ years, in addition to the priceless instructions from the veteran Machinist I was so fortunate to be exposed to. I believe their were 1 or 2 manuals that focused on those Metallurgy issues.
Good luck! Johnny
maybe you should start with some engineering book. at least i wish i had. e.g. tensile strenght is rarely what matters (→fatique strenght, shear strenght, buckling, youngs modulus, embrittlement (ssc/hydrogen), ductile to brittle transition temp, etc.). did you know a set screw (high strenghth) cannot be used in tension? you can look at quantitative info all day, but your just loosing time without the basics.
as to intro to machining, try blondihacks on youtube, if you like it.
Do you have any recommendations in that area? That sounds like an excellent idea. I have watched a few of her videos and they have been very informative.
Plenty of online information on materials.
this covers both to some extend and its available online (1733 p.):
DEPARTMENT OF DEFENSE
HANDBOOK
METALLIC MATERIALS AND ELEMENTS FOR
AEROSPACE VEHICLE STRUCTURES
What a great hobby you are starting to explore. And kudos one thinking first. Seems this is an antiquated idea these days.
Machinery's handbook does delve into strength of materials without getting into calculus. Anybody thinking about machine work needs this tome.
I like Atlas's "Manual of Lathe Operation" for learning about running an engine lathe.
Machining books never seemed very exciting to me.
In the interest of materials and machining I suggest toolmaking:
This is one of the most used books in my shop. It is absurd that it is $12 delivered. This is a big book and well written.
Take an average machine shop, add a nice stamping press or three, that book and a motivated individual and you have a recipe to make a lot of money today.
I have given this book as a gift several times, very well received. I should buy a few more copies at $12/ea. That's just nuts.
I would recommend you use the internet
There are hobby machinist sites that yak about everything
Look local in adult education classes for metal working, welding, and mechanical drawing
There are still libraries scattered around that have printed matter with pictures
