Domodude17
- Aug 14, 2017
Just started taking apart my 9A today. Have the tailstock apart, and the apron partially apart. I've just been using WD40 for gross debris removal, but I wanted to know if you guys have a better solvent that you would recommend. I have an ultrasonic cleaner, so everything that can fit in there will probably go in there with a mix of simple green and water.
As for paint removal, what would you guys recommend? I think I have heard people say oven cleaner works, and I have this REALLY nasty stuff that I used to pull oil out of a gun stock. It ate through two pairs of gloves and gave me minor chemical burn! After paint stripping, what should I do before painting? One last pass with a degreaser? Just rinse it off with water and dry with a hairdryer or in the oven on a low temp?
