Mfg_Engineer
- Aug 21, 2009
- FL
Rusty gaging surfaces.What makes it unusable?
Looking at it, it would seem that this is also a stack, by making them round they can mount the stack directly to the fine adjustment screw, which is clever. The Mitutoyo design puts the stack on a carriage. I could see taking the stack apart and replacing or "lapping and shimming" the measurement disks. Corrosion between the spacers and the disks is less likely due to the tight fit, so the spacers are likely still in good shape. If you sacrifice the bottom surface accuracy as the part will become thinner, the top could be lapped clean and the amount removed shimmed with precision bearing shims. May be worth a try...I think they do make some of them from stacked blocks, and it does seem like a lower-risk approach to manufacture.
+1 for this, if you want to use it on the shop floor and not in a metrology lab. I redid a B&S Hite-Icator. I found the column was assembled of gage block quality parts that needed to be wrung together in order to not have a cumulative error as they were assembled.If the issue is rust on the precision surfaces, you might do a thorough analysis to see if modest measures might make it modestly usable. If rust is only sporadic on the surface you may be able to recondition them and use the thing if you use it thoughtfully. Untreated rust has larger molecules than the original iron so will always be a raised surface. (Witness corrosion jacking in reinforced concrete) So in your case, you might be able to scrape off rusty areas without removing appreciable metal in good adjacent surfaces. Then in use, you'd just have to be sure your indicator point is finding an unblemished area somewhere on the relevant ring and do your reading. In my experience, the indicator is used as only a "null device". zeroing on the feature of interest, then bringing it to the gauge to again zero and read the actual dimension off the gauge. So you can wave the indicator around a bit on the nearest ring, or in the worst case gauge a little up or down and add or subtract the new number or the indicator.
Notice
